LM431 as over discharge protection
gkeep
Joined Oct 21, 2017
76
Hi Guys,
I'm a bit stuck on building an over discharge protection circuit for on of my projects. Its basically running an RC lipo battery (2S). I want to protect it against over-discharge. Can someone tell me if this circuit is on the right track? Its my first attempt building a circuit with an LM431.
DickCappels
Joined Aug 21, 2008
10,661
Unfortunately the anode will act like a voltage follower and very slowly thurn off the mosfet. I think you will be much better off keeping the anode grounded and taking the signal from the cathode to turn off the mosfet.
A PNP in the cathode curcuit with appropriate resistors can switch the mosfet on and off. (One possible approach).
Alec_t
Joined Sep 17, 2013
15,167
Ideally each cell of the battery should have its own over-discharge protection circuit, Otherwise, if the cells were unbalanced, one could discharge below a safe level before your 2S circuit kicked in.
gkeep
Joined Oct 21, 2017
76
So, something more like this?
I might be way off. but I think this looks kind of right, I'm also not 100% sure if this is the right choice of pnp transistor.
Thanks for all your help!
What do you think?
gkeep
Joined Oct 21, 2017
76
Thanks Alec_t, I did think of that. The cells will be balanced every time the battery is charged so, with this voltage divider will trigger the zener at 6.5V (instead of 6) to be safe.
gkeep
Joined Oct 21, 2017
76
Oh yeah, sorry that pnp should be flipped on its horizontal axis.
Its okay. I think its probably wrong anyway. I don't know how to get all that info on LT spice.
ericgibbs
Joined Jan 29, 2010
21,646
hi gk,
Still not working as you expect.
At what voltage do expect low level cut off.?
E
BTW:
Remember that when the load is removed from the battery by the cut off circuit, the battery voltage will most likely rise.
You need hysteresis in the switch
E
gkeep
Joined Oct 21, 2017
76
hi gk,
E
BTW:
E
regarding hysteresis in the switch, Do you mean like a flyback diode? or do you mean because of the internal resistance of the battery will raise the voltage once the load is removed?
hi gk,
Unzip this zip file.
E
I found your thread on the TL431 and imported it into LT spice that doesnt seem to be the problem.
gkeep
Joined Oct 21, 2017
76
I'm probably going to give up.
I'll just use a ZY12PDN and a PD power bank. Much more expensive but over-discharge protection is too hard for me.
Thanks for your help.
