LM393 unused pins Connection
Khsar
Joined Nov 8, 2019
I am trying to design a circuit to control the outdoor light on and off using ldr.
I test the following circuit,
i used one comparator of lm393.
*should i connect the other input and output pins of the second comparator. or leave them unconnected ?
*should i do any modification on the design?
i used this relay module
ericgibbs
Joined Jan 29, 2010
21,523
hi khsar,
Welcome to AAC,
You could connect +Vin and -Vin to 0V, leave the output pin open.
Add some decoupling on the 5V supply of the LM393 supply, say 10uF and a 100n
E
