Delta Prime
- Joined Nov 15, 2019
- 1,311
No, it is on a solder board, but I will check the power/ground pins to circuits. I did check the voltage bus on the board with various combinations of LEDs lit and it stays steady at 4.95V. Thanks for the suggestion.
Can you take a photo of your circuit board, top & bottom side. Just to get a gander at component placement signal,power buss, things like that.
