I am aware of the 555. I have just built a emergency vehicle strobe quad light set up controlled by 1 x 555 and 1 x 556 so I have plenty of bits if required, what is your train of thought??
Transducer
Transducer
Greetings transducer,Hi hgmjr,
Sorry for the delay in posting but the time difference here in the UK meant it was way past my bedtime when you posted the cct. Many thanks for the schematic. I built the cct in Livewire and although the circuit does work in theory there are issues, I can only get the leds to flash at FSD if ALL LEds are fed via the 100R, if the circuit is set up as designed with only the trigger LED fed via the 100R then the array does not flash at FSD,please see attached. Also what size cap is meant to be on pin 5 as the schematic has no value.
Thanks again for your help
Transducer
Greetings transducer,hgmjr,
Not had chance to try your circuit yet, but will post my findings as soon as I get the time
JoeJester,
It is a 4 cylinder engine with a max rpm of 8000
by Jake Hertz
by Duane Benson
by Jake Hertz
by Jake Hertz
