LM3914 Battery voltage indicator
eetech00
Joined Jun 8, 2013
4,713
since usage of voltage regulator becomes a mandotory thing as my led consume 20ma, therefore suggest me with use of voltage regulator and also do suggest me some small voltage regulators
The circuit below is 1v per LED segment and is fully lit at 25v. Each LED operates at approx If=20mA using a KingBright DC10EWA Bar graph (should be plenty bright). The regulator is a TPS7B82 5.0v LDO regulator and is available in different packages. You'll have to review the datasheet and choose a suitable package.
