Hi Munro, I'm trading on eggshells here, but I'm really thinking that the best way to learn is step by step and I'm concerned that you are working with mains voltages here, where it's especially important to understand what's going on. The "sawtooth" waveforms are a consequence of voltage drop as the rectified AC is at low voltage and the 4700uF capacitor C4 is trying to maintain the peak voltage but dropping due to current being drawn. The bigger the current drawn, the bigger the voltage drop between (half) cycles - the bigger the capacitor the smaller the drop.im tryin my best to understand the graph and what would be the result, is it good or no? im sorry im totally noob
ok noted. i have more transistors here like mjl21194, maybe it will help, i will providebigger heatsink,and fanshi m,
I assume you have a copy of the LM358 datasheet.? attached, it is a dual OPA.
Be aware of the additional heating if you set the Vout to +12V at 3Amps, the Green plot.
E
View attachment 275332View attachment 275332
i understand, yes i have lm317t, ive done a very simple circuit using that. but because i like to explore, i tried searching the web for an op amp with transistor power supply, and i came up with this circuit. as a beginnee, i loke discovering things, and yes, im aware that im working on high voltages. i do this just for hobby since im still studying. but , thank you, i really appreciate each and everyone of youHi Munro, I'm trading on eggshells here, but I'm really thinking that the best way to learn is step by step and I'm concerned that you are working with mains voltages here, where it's especially important to understand what's going on. The "sawtooth" waveforms are a consequence of voltage drop as the rectified AC is at low voltage and the 4700uF capacitor C4 is trying to maintain the peak voltage but dropping due to current being drawn. The bigger the current drawn, the bigger the voltage drop between (half) cycles - the bigger the capacitor the smaller the drop.
Dare I ask if you understand the rest of the circuit? A bench top supply is indeed an essential piece of equipment and I completely understand that you need one. For most of my needs I get by with an LM317 with a potentiometer to adjust the output voltage using an old 19V laptop power supply as the input. Really safe to play with and most of my projects need anything from 2V to 15V DC supply and well below 1.5A so I only use a small heatsink and rely on the LM317 thermal overload protection to limit the power. When you decide to build something that someone else has designed I highly recommend that you understand the purpose of every component part - the best way to learn, and it helps you to move on to adapting the ideas of others. I've only just joined this site and I've tried to contribute and have already learned a fair amount that I didn't know before! Good luck with your journey, sorry if I'm out of line, not meaning to offend.
hi, i want to clarify again, d3 doesnt have series resistor? thankshi m,
E
ive seen some circuit uses a resistor before zener, they say it limit current so that the zener will not fail, but maybe thats different cases. anyway, i dont have that d3(bzx84c12), what other value of zener can i use? thankshi m,
Has someone told you should have a resistor.?
Where would you place it and what value.?
E
| W | Review Request: 220V TRIAC Voltage Stabilizer using LM358 and UJT | Homework Help | 8 |
