LM358 VCC
MisterBill2
Joined Jan 23, 2018
27,520
That supply will require a DC input of some voltage, and ( DC Buck Converter, DROK DC to DC Step Down Power Supply Module 10V-65V to 0-60V 0-12A Adjustable Voltage Regulator) it is only good for a max of 1.2 amps. But three of them in parallel would work.
muno
Joined May 17, 2022
95
mostly laptop computers. many of them are rated 19V 3.47A, but i think 25V 3A would be fine, since my transformer is the limit. 28-0-28 120VA
muno
Joined May 17, 2022
95
thanks for the responses, but im not so familiar yet with the parts, can you suggest which of them? im so sorry for im still learning electronics in college. i have lm317t here but dont know how to insert it in the circuit. i also have 2n3055 transistors,
muno
Joined May 17, 2022
95
thanks, so i can use the whole schematic below? i think 7k resistor is not readily made available?
MisterBill2
Joined Jan 23, 2018
27,520
powering a small computer with a voltage that is much too high will probably cause overheating, even with the internal supply being a switcher. And even if nothing burns up right away, that excess heat will certainly promote other problems.
What sort of rectifier scheme are you using to get the 40 volts? If the transformer has a center tap not in use that can be reduced by not using a bridge rectifier.
So please give us a bit more description of the input portion, the solution might be easy.
muno
Joined May 17, 2022
95
hi i will be using full wave center tapped
I'm wondering how important it is for you to build this circuit - I like to do stuff myself, so I get it, but had you considered using an LM317 linear regulator. They are cheap, with input voltage up to 40V and the only limitation is 1.5A maximum. There is probably a trick to run two in parallel to get the 3A you are looking for, or mimic the internal circuitry with a (darlington pair) power transistor which, with a suitable heatsink, can handle the 3.0A current with nearly a 40V voltage drop.
