LM35 temperature control circuit
Shakespeare
Joined Sep 12, 2022
16
I am building a temperature control circuit to control water temperature. The temperature has to be regulated between 80-85°C. I'm using LM35 template sensor. And ua741 op amp.
My question is should I use two op amps to created a window comparator or use resistors to create schmitt trigger? What is the difference between the two?
Alec_t
Joined Sep 17, 2013
15,156
Welcome from me, too!
What supply voltage(s) will you be using? The 741 op-amp is from way back in the dark ages, is intended for a dual-polarity supply, and doesn't like inputs within a couple of volts of either supply rail. The LM35 at 85C will only be putting out 0.85V.
A cheap and cheerful improvement would be e.g. an LM358 (dual op-amp) or LM324 (quad op-amp), or an LM339 (quad comparator).
38,825
As Alec noted, a 741 is not a good device for your requirements unless you have dual supplies.
Since you want a comparator function, I recommend an LM339 or LM393 comparator.
Edit: Removed comment about using a window comparator since I realized you need a comparator with hysteresis.
Shakespeare
Joined Sep 12, 2022
16
I will be using 12V. Also a 12V relay to control the heating element
Shakespeare
Joined Sep 12, 2022
16
If you do use one of those, their outputs can be easily AND'd together with one pull-up resistor to provide the window comparator function, which is generally more accurate than using hysteresis.
Thank you. With LM339 how would I get a hysterisis of 810mv-890mv and switch on volatge of 850mV. What's resistors to use if you know of any formulas. Supply voltage is 12V
Ian0
Joined Aug 7, 2020
13,279
Don't use an op-amp as a comparator. Use a comparator.
