Hi all,
Maybe a daft question, I've got some lm35's in the t220 package, I want to use it to sense the temp of a copper pipe.
I'm soldering the joints on the copper pipes, if I solder the tab to the pipe will I do any damage to the sensor?
If it works after I solder it does that mean it will continue to work or could damage show up later?
Has anyone else done it like that? I know I could just use a jubilee clip but solder would be tidier and transfer heat better.
Cheers Geoff
Cheers Geoff
