LM338 Variable power supply
JustMe234
Joined Feb 25, 2017
68
I am build a variable power supply with LM338 but i cant find schematic for both voltage adjust and current adjust in same place.
Thank you very much
AlbertHall
Joined Jun 4, 2014
12,654
The nearest you can get to this with the '338 is the circuit below from the datasheet. Make the 1.1k your voltage adjust and change the value of the 0.2Ω for the minimum current you want. Connect a pot across that resistor with the wiper connected to the 100Ω resistor to adjust the current limit. This would usable provided you don't want to set the current too low.
Or there is this design which uses two LM338, one to set the current and one to set the voltage. But I think it makes more sense to use an IC which does include both functions like the '723 suggested above.
Dodgydave
Joined Jun 22, 2012
11,395
The only way is to use a series resistor in the Negative rail with a transistor, (Or an op amp current sensor if you want variable current limit .) The low resistance has to drop the 0.7V to turn on the transistor, this then lowers the output voltage.
38,871
I think the 5k pot in that circuit is mis-connected. The 1.1k sets the output voltage.
Yes, the 5k pot should be in place of the 1.1k resistor.
That way the voltage drop of the current sense resistor does not affect the output voltage.
Below is the LTspice simulation of the circuit with the pot moved.
It's set for a 5V out with a 1A limit.
The load voltage and current are show for loads of 2, 4, and 10 ohms.
Not that these circuits cannot control the limit below an output of 1.2V
Thus the short circuit output current is limited only by the intrinsic regulator current limit.
38,871
Here's a current limiter which can be adjusted from zero to it's maximum, that goes in front of the regulator.
The maximum current is determined b the value of R3. The value shown gives maximum of about 5A.
M1 must be on a heat sink since it has to dissipate the limit current times the input to output voltage drop.
