sob !!!!thanks a lot rifoo
I have had to quote/edit your post as the image was not displaying.thanks a lot SgtWookie
The Part 1 schematic shows the most basic schematic from the datasheet for a current limiter.in this diagram
if i desired current = 500mA
then R2= 2.26Ω (VRef U1/Current)-R1 using you type this formula [I have corrected your formula]
i am ok or not
i am desired for current limiting using this digital cct
use fix resistance
My problem is not solved
because i am trying to make digital current limiting cct
Attatch image
if Q1 is on than output current = ?
if Q2 is on than output current = ?
if both in parallal than output current = ?
this cct is ok or not
R2 and R3 wattage 1/2 W
using counter change the resister
Resistor use in 1,2,4,8,16 step current 100,200,400,800,1600mA step
Please help me
2. Why output not short. i am seen any current regulator supply, current variable vary the output current if the output short and current meter across it for display max output current regulate
Please Explain itNow I can see the image. That one is obsolete, as I made a couple of errors in it.
In the data sheet the variable resister value = 150Ω that output current vary the 0-5AR3 is easy. R3 = R2 = 125 Ohms. This provides 2.5A output.
R4 = R3*2 = 250 Ohms. This provides 1.25A output.
If you add an R5, it would be R4 * 2 = 500 Ohms. This provides 625mA output.
If you add an R6, it would be R5 * 2 = 1000 Ohms. This provides 312.5mA output.
Please dont expalinQuote:
But this cct R6 = 1000Ω
Please explain
In the datasheet, they used a 150 Ohm pot (potentiometer) for R2.Thanks a lot SgtWookie
My problem is solved
Very Very thanks a lot
Please explain
These question for knolodge improvement
Because my problem is solved
very very thanks a lot SgtWookie
I do not see the LM317 current sink in your block diagram. If they are in the digital control circuit portion, then it is OK.Final Block diagram is attatched and please brief that is Ok or Not
No damage as long as you have a LARGE heat sink on the LM338 so that it does not overheat.2. if the out put load short than max 5A current and no any damage (this state is true or false)
The second block (LM338 Digital current regulator) use this cct -Ve supply use this cctI don't know why you have -ve going directly to the 1st LM338.
Digital voltage regulator cct AttatchNote that you have to account for the extra current that the 2nd LM338 will require for its voltage control circuit, otherwise your current limiter will be too low by that amount of current. You need to show how you are planning to control the 2nd LM338.
How many large 1x1 or 2x2 heat sinkNo damage as long as you have a LARGE heat sink on the LM338 so that it does not overheat.
I am having to quote your reply and edit it, since the image did not attach correctly.The second block (LM338 Digital current regulator) use this cct -Ve supply use this cct
Here is the voltage regulator circuit that you attached:
You need to first determine the Vref of this LM338.How many current use for this block (LM338 Digital voltage regulator)
If the low side of R2 is connected to ground, you will not be able to output a regulated voltage less than Vref, even if R2=0 Ohms. Vref will be between 1.2v and 1.3v, inclusive.Resistor R2 use Fix Resistor(In series no of Bits 1,2,4,8,16,32) Bits control through relay cct (Open or short resistor)
It depends upon what voltage you are using for the input supply.How many large 1x1 or 2x2 heat sink
i attatch the imageI am having to quote your reply and edit it, since the image did not attach correctly
Image 2 attatchIf the low side of R2 is connected to ground, you will not be able to output a regulated voltage less than Vref, even if R2=0 Ohms. Vref will be between 1.2v and 1.3v, inclusive.
if i am using heat sink made from aluminium than please describe any problemYou will need a heat sink large enough to dissipate 144 Watts, or the LM338 will go into thermal shutdown. This will be a large heat sink made from copper with a big fan blowing cool air on it.
