LM324 or LM556 for PWM Signal
Xavier Pacheco Paulino
Joined Oct 21, 2015
728
I have attached two pictures about PWM. One PWM is built using LM556 and the other using LM324. My question is: Is there any difference in performance when using either the one with 556 or the one with LM324?
dl324
Joined Mar 30, 2015
18,473
Personally, I think pmw1a is more straightforward. But I'd use an actual comparator instead of an opamp for the U1b and replace U1c with a voltage divider.
DickCappels
Joined Aug 21, 2008
10,661
You will be bale to get high pulse rates out of the NE555.
I am not certain but I am pretty sure that the approach using the LM324 will enable a wider range of pulse widths.
