lm318p not working??
caoadon
Joined Jul 11, 2014
24
Hi
I've built an inverting set up with a lm318p op amp,
but I can't seem to even get an inverting signal in general?
I just want to get it working so right now the gain is only 1 (using two resistors of same value)
Ive posted a picture
shteii01
Joined Feb 19, 2010
4,644
I see ground.
I don't see power. You have red plug plugged into breadboard red socket. Normally from red socket you would run a wire to the breadboard. But you got nothing running from red socket to the breadboard.
ericgibbs
Joined Jan 29, 2010
21,557
There's something there. its just a black wire
hi,
On some types of project board the power rails [ along the long edges ] are not linked thru at the centre pins.
So if your gray wire is your scope 0V, it may not be connected!.
Move your scope 0V lead to near the power input rail.
E
caoadon
Joined Jul 11, 2014
24
Tried that also. Didnt work! :(
But thanks though
Does it have to do with the parameters I have on the function generator?
1kHz, 100mVpp 50mVos
JoeJester
Joined Apr 26, 2005
4,390
I noticed the wire you have connected to pin 3 (Vcc-) is connected to your Vcc+ ... assuming that red wire is Vcc+
The area around the posts is very unclear. Neaten up your diagram ....
