I have built this circuit with LM317T and LM337T:
The problem is the output voltage will drop under load when i have C3 and D7 connected. Unloaded the voltage over R1 is 1.1 volts, and if i connect a load (LED and 1k resistor) it drops to 0.9 volts. Without C3 and D7 it works and the voltage over R1 is 2.2 volts. Same problem on the bottom side.
