drop-out voltage can reach 1v in very hot / low load conditions.Cant be 37v out with 38v input.
Hi, You are right LM317 is damaged. I replaced a new LM317 and checked the continuity, it was ok. But circuit damaged it again.Hi
I think the LM317 is damaged. Cant be 37v out with 38v input.
Should only be about 5mA thru R2 (ADJ) resistor
Hello,Hi, i checked Lm317 its short but why LM317 short all the time. I replaced a new LM317 and checked the continuity, it was ok. But circuit damaged it again.
Till now i have connected SIX LM317 but all got damaged after powering on.
sometimes adjuster and Vout short and sometimes vin and vout and once i got all three pins shot.
Please suggest.
The current through R2 is (Vout-1.25 )/R2Hi
The schematic looks okay. Input voltage is a bit high for the LM317. Maybe try LM317HV. Capacitor is overheating???? Rectifiers wired correctly?What's the power dissipation over the pit at 37vout?
HiHi, You are right LM317 is damaged. I replaced a new LM317 and checked the continuity, it was ok. But circuit damaged it again.
Please suggest.
No over heating, caps are all ok and rectifiers are wired correctly.The schematic looks okay. Input voltage is a bit high for the LM317. Maybe try LM317HV. Capacitor is overheating???? Rectifiers wired correctly?
How much voltage did you actually need out?
An insulator isn't necessary if the heat sink is not touching anything else, which it does not appear to be.Do you have an insulator between the LM317 and the heat sink?
well...it shouldn't...but...An insulator isn't necessary if the heat sink is not touching anything else, which it does not appear to be.
by Robert Keim
by Duane Benson
by Don Wilcher
by Aaron Carman
