LED failure is a extremely rare thing, as long as the current stays within a sensible range.
Using eg. an LM317 all LEDs might kick the bucket if the LM317 failed.
I have had about 3..5 LM317 fail short (i.e. full voltage on the output) over the years, but the only LED's I have killed were by purpose or an *oops, was the PSU set to 30V/10A?*
So I know which circuit I'd personally be using.
LED's failing open is less than 1 in a thousand, the normal failure mode for any diode is short circuit.It works in simulation, but LED1 or LED2 could be an Achilles' heel if either of them opened up. That would cause the rest of the LEDs to get maximum current flow through them; then they would all have to be replaced. If LED3 failed open, all the other LEDs would simply turn off.
