LM317 circuit producing insufficient current
abdulwahab.hajar
Joined Jun 14, 2016
93
I made a very simple circuit as in the attachment
It's supposed to output 625mA, but only outputs 500mA in actuality....
any insights as to why this is happening? is it a reasonable marginal error?
I tried decreasing the resistance such that an output of 825mA is expected but only reached around 600mA...
I actually want it to reach it 1.2A, but at this rate it seems highly unlikely....
Thanks for the help
bertus
Joined Apr 5, 2008
23,006
You show a simulation.
What is the actual 9 Volts source?
If it is a PP3 battery, the current will be limited by the internal resistance of the battery.
As the capacity of a PP3 battery is quite small, you will have a short lifetime.
Bertus
abdulwahab.hajar
Joined Jun 14, 2016
93
Bertus
I'm actually using a 12V adapter... it's capable of providing 2A
Bordodynov
Joined May 20, 2015
3,431
Abdulwahab.hajar.
Quickly measure (short-term) the short-circuit current of the battery (if it is not a rechargeable battery) without your current generator.
P=(9V-1.25V)*1.25V/2= 4.84375W !!!
abdulwahab.hajar
Joined Jun 14, 2016
93
What is the measured input voltage and what is the voltage across the load?
Input voltage is 12.6, voltage across the load is 0.7.....
Actually I just noticed that the voltage across the output and adjust isn't 1.25V it started out as 1.25V but Quickly dropped to 0.55-0.7V
Could it be the heat???
