LM2907 using questions
davidbr
Joined Apr 25, 2018
60
Hi all,
I am using a LM2907 chip to read a wheel rpm. Basically I have a metallic wheel and a whole in it, where I put an inductive sensor which is closed or open depends if is on the whole or on the wheel. The circuit is working but still I have some "issues / questions" about it.
The senor is also operating at 12V. I have the wheel connected to an electrical screw driver and when is not moving I read about 0.3V and when is moving on maximum speed I read about 2.1 V. The readings are done using an ads1115 and an arduino nano.
Now my questions :
1 - When I start moving wheel the voltage is increasing pretty fast till maximum, but when I stop the wheel it needs about 2 or 3 seconds till get back at 0.3V . How can I change the circuit for get a faster response ?
2 - How can I calculate the frequency I read using voltage I read?
Thank you very much
ericgibbs
Joined Jan 29, 2010
21,442
hi David,
What is your best guess at the actual frequency of the sensors pulses, also the duration of the pulses.?
You could use the ADC input of a an Ardunio and then calc actual frequency, but you need some ref rotation/speed point.
E
jpanhalt
Joined Jan 18, 2008
11,087
From the datasheet:
It appears R1 can be chosen independent of ripple, however response time, or the time it takes VOUT to stabilize at a new voltage increases as the size of C2 increases, so a compromise between ripple, response time, and linearity must be chosen carefully.
Your C5 (datasheet = C2) may be a bit large.
From a broader view, you are changing a frequency (digital) to voltage and voltage back to digital. Why not use the arduino to measure the frequency directly?
danadak
Joined Mar 10, 2018
4,057
Note C2 (datasheet C2) being electrolytic typically has very loose tolerance
from one part to another. So consider than when choosing a cap. Maybe a
MLC would be a better choice. Datasheet shows a typical of 1 uF.
Regards, Dana.
eetech00
Joined Jun 8, 2013
4,705
Hi all,
Now my questions :
Thank you very much
Hi
1. You can get a faster response if you lower the value of C5 and increase R7 while retaining the same RC constant.
2. Frequency calculation. I believe the equation would be:
Freq=Vout/(Vcc*R7*C5*K)
Where K=I2/I3
And
I2=AvgCurrent Pin2
I3=AvgCurrent Pin3
eT
ScottWang
Joined Aug 23, 2012
7,501
Hi
Freq=Vout/(Vcc*R7*C5)
eT
Freq=Vout/(Vcc*R7*C4), C5 is a bypass capacitor, Pin 2, 3 all Charge Pump pins, please check the circuit in page 9 and the equation 2 in page 10 of the datasheet.
LM2907 datasheet.
