Hello, I was trying to current control the o/p of an LM2576, by feeding in o/p of an opamp as mentioned here :
http://www.smbaker.com/lm2576-constant-voltage-constant-current-switching-power-supply
But, the limiter is not quite accurate, lets say, if I set the limit around 400mA, LED starts glowing after 400mA is crossed, and becomes brightest after more 15mA or so. That is also when the final current limit takes place(i.e. increasing voltage does not increase current).
Also, when I measure the feedback pin voltage at current limit state, it shows around 1.7V, which was supposed to stay at ~1.24V.
Considering feedback pin is only the input to an internal comparator in LM2576, I guess it should not hurt the IC much, but I would like to know why is it not behaving the ideal way (i.e. 1.24V at feedback pin). Also, if there is any way to improve performance, kindly suggest.
