LM 3915 Vu meter
Kristaus_tevas
Joined Feb 19, 2015
4
I made LM3915 Vu meter which is working fine, however i have some problems.
I used this schematic:
http://users.otenet.gr/~athsam/vu_meter_4.htm
At R1 I used 10Kohm potentiometer and for input I connected 3.5mm jack.
When I connect my VU meter to my laptop it lights up to 4 LEDs, so I have to connect it to my speakers (which gives higher volatage, as I understand) and only then I can light up all LED's, however I need to be able to light it up from laptop.
Can anyone recommend me any amplifier circuit that would be easy to fit up into this schematic and would solve my problem?
Also my dot-bar switch doesn't work, when I switch it on/off it changes only brightness of LED for some reason, but it still is in bar mode.
GopherT
Joined Nov 23, 2012
8,009
You can make the circuit more sensitive by reducing the value of R4 in the given schematic.
Here is a picture taken from the datasheet how to calculate the reference voltage:
You can reduce R4, this will lower the full scale setting,or reduce R1 to zero, otherwise you need an amplifier.
You are both talking about R4 but your schematic only shows R1 and R2.
EDIT - I see, you are talking about R4 in the OP's drawing.
Dodgydave
Joined Jun 22, 2012
11,395
I would make R4 a 4K7 preset, then set it to the middle and slowly turn it to zero whilst your laptop is connected with sound up full, then the leds will start lighting up.
Kristaus_tevas
Joined Feb 19, 2015
4
I have connected 50k ohm potentiometer parallel, and when I lowered his resistance it lit up, but now almost all the times leds 1-6 are lit up, 7-8 are moving and 9 sometimes lights up too. But it looks really not responsive, and if I increase resitance it just differates between which leds will light up. But it's always only 3-4 who moves nicely, what should I change to make it work more responsively in whole scale instead of 3-4 led's?
bertus
Joined Apr 5, 2008
22,930
You say that when the R4 is shorted, led 7 and 8 work and 9 sometimes lights up.
You can try the following: Short R4 and place the 50K pot between pin 6 and 7.
Start with the lowest value and turn it up until the wanted response.
Dodgydave
Joined Jun 22, 2012
11,395
The problem with an Lm3915 is its not linear, with each led step you need more voltage usually double the step, where as a Lm3914 is the same voltage per step.
