Lithium Ion Battery Cell voltage vs SOC vs Amp hours
MikeJacobs
Joined Dec 7, 2019
232
I am trying to figure out how to explicitly correlate battery Amp hours with State of charge and voltage
So as we generally accept, an Lithium Ion cell
Has a min low voltage of 3.2V and a max of about 4.2 volts
ok great no issues here. We also would say that at 4.2 volts its at 100% SOC and at 3.2V its at 0% SOC???? Is that true?
Also, i have a 1 amp hour battery and i drain 1 amp out of it for one hour long
i will be at 0% SOC but is that 3.2V or is that 0V??
Im trying to understand how amp hours relates to SOC is the big question here.
If i drain all the amp hours out of an Lithium ion cell, is it at 3.2V or is at 0V??
If it goes into BMS under-volt protection it might be 0V until the condition is cleared by a recharge cycle. Normally about 3.2V is 0% SOC
MikeJacobs
Joined Dec 7, 2019
232
3.2 volts at 0% SOC
But what im trying to understand is, if you remove 1 amp for one hour from a 1Ah battery what is the cell voltage?
Is it 3.2V or is it 0V?
Im trying to understand the correlation between amp hours , cell voltage and SOC
