Linux Source Code Folder Structure
King2
Joined Jul 17, 2022
163
I've recently taken a deep dive into the Linux source code, and I'm excited to learn more about the inner workings of this powerful operating system. As I've been navigating through the source code directory, I've come across a plethora of files and folders, each seemingly serving a specific purpose.
https://elixir.bootlin.com/linux/latest/source/arch
I see the "drivers" directory contains subdirectories for various hardware components. How do these driver files interact with the kernel, and user application?
dl324
Joined Mar 30, 2015
18,476
Essentially, the driver files are compiled into object libraries. User applications invoke specific drivers via library functions when they want to access specific hardware. The driver code often runs at elevated privileges and interacts with the kernel to access the hardware.
joeyd999
Joined Jun 6, 2011
6,460
You should consider building a kernel. It's not all that complicated, there's plenty of tutorials online, and you'll start getting an idea how things work under the hood.
King2
Joined Jul 17, 2022
163
I appreciate your explanation about how driver files are compiled into object libraries and how user applications utilize library functions to interact with hardware drivers. However, I'm a bit fuzzy on the concept of kernel space and user space, particularly when it comes to privileges. Could you kindly shed some light on this aspect?
Thank you for your encouraging words and advice regarding building a kernel. I 've downloaded and compiled a kernel on my Ubuntu PC
I'm curious to know if anyone ever ventured into the realm of Linux device driver development. Given your insightful input on kernel development, I'm intrigued to hear about your experiences in this area and any advice you might have for someone looking to explore device driver programming.
dl324
Joined Mar 30, 2015
18,476
There is a lot written about this. Basically, kernel mode is reserved for the most trusted operations, often operating with elevated privileges. User mode is for everything else.
Sure, I've done it and have a few drivers in the current Linux kernel. This is a old one for a DAQ-700 PCMCIA card.
https://git.kernel.org/pub/scm/linu...rivers/comedi/drivers/ni_daq_700.c?h=v6.5-rc5
https://forum.allaboutcircuits.com/threads/real-world-application-for-rtos-ml.182350/post-1674356
https://forum.allaboutcircuits.com/threads/a-few-questions-about-an-audio-codec.152269/post-1307454
