panic mode
- Joined Oct 10, 2011
- 5,303
even on Windows i am using VMs for some of products. this is fine for things not used daily. booting VM also takes time, once it is running most of things are pretty normal or near native performance. but each VM takes additional resources like RAM. Some software also may require dedicating CPU cores. i don't really like this as low level resource configuration changes require rebooting. and leaving it permanently on may interfere with other VMs - if that happens the only way out is cold boot...
so far i got things as efficient as i could but it is by no means a perfect setup. challenge is that there is a lot of different products i need to use. and i tried many things including removable or external drives etc. if things are calm, i get to work with few products for a week or two, so reboot or starting VM or two is not a factor... but, there are times where i need to change to something completely different several times a day. fast machine helps as a lot of time it is me waiting on a computer. one nice thing is that old work machine makes for a really nice home computer.
