Linearity in amplifier stages.
Rohit156
Joined May 18, 2018
11
How linearity is maintained to i/p to o/p in amplifier with considerable gain at cost of efficiency and stability?
Rohit156
Joined May 18, 2018
11
So far I learned that for keep it input linear it must be coupled to amplifier such that it will be less than Vt. (Considerable bjt device)
Or consider for cmos with condition of I/p coupling far less than Vgs-vth .
Now question is
How linearity is maintained from one stage to another in process of archiving higher gain?
For eg : if suitable input is applied to first stage of amplifier unit let's assume it have considerable gain such that it will surpass our approximation that I/p must be far less than Vt, so how further stage keep in track so that it will more will have more gain than previous stage with less compromisation with linearity.
Rohit156
Joined May 18, 2018
11
OR you give the amplifier 1000x more gain than it needs and use feedback. Here the gain is set by the resistors and not the internal errors of the amplifier.
[/QU
Most bipolar opamps have 3 stages. Each stage is biased to operate in it's linear region. In most opamps, the second stage is compensated for stability.
I would like to know how further stage would be kept in biased in linear region so that previous amplifier o/p swing will be tolerable to a limit so that it doesn't steer into another region? Are there any other special amplifier configuration to handle this?
Rohit156
Joined May 18, 2018
11
Now question is
Assuming it has already properly biased to be in linear region with AC coupled from I/p , curious to know about behavior amplifier o/p swing tolerable to further stage to operating properly with less compromisation with linearity.
Please Clarify , your precious response will be appreciated.
38,749
If you want HIFi level linearity (<1% harmonic distortion) in a transistor stage, then the state usually has some negative feedback.
This also stabilizes the gain and makes it less dependent upon the individual transistor current gain.
An easy way to do this is to have an emitter (BJT or source (MOSFET) resistor that is unbypassed.
To allow for independent setting of stage bias and the amount of feedback, two resistors are often used, with only one of them AC bypassed with a capacitor.
Below is the LTspice simulation of a single-stage BJT amp illustrating the difference in distortion and gain.
It can be seen that the V(out) yellow trace with an unbypassed 100 ohm emitter resistor has noticeably lower distortion than when it is shorted out by S1 (blue trace) where the top of the trace is noticeable flatter than the bottom of the trace.
The tradeoff is that the gain is about 4 times less with the feedback (input signal is 4 times larger).
This distortion is mostly caused by the logarithmic relation between the base input current and voltage as shown in the bottom base [ib(Q1)] current traces.
Rohit156
Joined May 18, 2018
11
Thank you for you contribution for making discussion more meaningful so far.
Still one question I would like to ask,
How tradeoff between linearity and stability can affect amplifier performance?
