Line and Load Regulation
Tobias12
Joined May 25, 2019
25
How can I calculate the line and load regulation for an oscillator ?
For exemple: A non-sinusoidal Oscillator
When I calculate line regulation delta(Vout)/delta(Vin) I didn't know what is Vin, because an oscillator doesn't have an input source.
AlbertHall
Joined Jun 4, 2014
12,652
'Line' in this case might be the oscillator supply voltage.
However, for an oscillator, it is more likely to be the output frequency variation with supply voltage and loading you would be interested in.
DickCappels
Joined Aug 21, 2008
10,661
You could relate the change in output amplitude to the change in power supply voltage, if that is what you are interested in. What is it that you would like to express? Why do you want to calculate those things, whatever they are?
Delta Prime
Joined Nov 15, 2019
1,311
Hello there
There are specific guidelines and tips for measuring proper line and load regulation by vendors such as TI, NI and ST. .
