Lightsaber wiring assistance.
Bedean
Joined Mar 9, 2019
No it's not a functioning lightsaber ok so I'm a novice when it comes to wiring. And after a year of trial an error... soooo mush error. Ive decided to start from scratch an ask for assistance.
The plan is simple. I need 4 LEDs (2 blue, 2 red) and a tiny vibration motor, all connected to a rechargeable battery. Ik I bit off way more then I could chew.
My biggest issue was finding a power source small enough and strong enough. So I decided that's where I'm going to begin. I decided to go with something like this. Tenergy PCB Protected Rechargeable Li-Ion Battery Module with Bare Leads, 3.7 V, 2600 mAh
Would that be enought to power what I need? What LED, motor, resistors, charging materials, do you suggest? ALL IDEAS ARE WELCOME.
Just remember I'm dealing with a cylinder that's 9 in tall an about a 1 1/4in diameter. For the hidden components in the hilt I have 4 1/4 in to witk with. While the LEDs will illuminate the crystals in the viewing window the top 5in
I'm just here gathering thoughts before I start down this road again. Thanks for reading and any advice!!!
dl324
Joined Mar 30, 2015
18,446
Welcome to AAC!
Seems like plenty of power, but the voltage is too low to light a blue LED. You're going to need a step up regulator.
LED - whatever suits you. High brightness will use less battery power.
Motor - Get one that the size you want. I'd pick a low power variant.
https://www.jameco.com/z/6ZK003-R-Vibrating-Motor-1-3-Volt-DC-80-mA_256306.html
Resistors - depends on the voltage you settle on.
Charging materials - get a chip that supports Li-Ion.
djsfantasi
Joined Apr 11, 2010
9,237
Can you take a picture of how you think you’ll wire it up? And I have some questions of the physical layout.
Are the LEDs in the base or spread throughout the tube? And where is the motor and what’s its purpose?
Bedean
Joined Mar 9, 2019
I'm not putting a blade on all components (cept LED) need to fix in the handle under the crystal chamber. The motor is for nothing but vibration like you would find in a cellphone or game controller. Ment to simulate the vibration of a Kyber crystals.
Bedean
Joined Mar 9, 2019
Sry I forgot to quote see comment above
Bedean
Joined Mar 9, 2019
Welcome to AAC!
^can I find a step up regulator that small?
^ok so bright as I can get lol
^ty I've been looking for this!!!
Bernard
Joined Aug 7, 2008
5,784
Specs on the LEDs would be helpful. My blue LED Vf 3.2 V @ 25 ma. yours might be more powerful ?
I would wire all LEDs in series & use a boost converter. If red & blue LEDs do not draw the same current
parallel lower current ones with app. resistors. Run motor direct from battery or add small resistor as necessary
for desired shake .
