The sculpture will sit on the ground and be built around the sound and light equipment,i wouldn't be to concerned about prying fingers as the pir's could be secured to some timber or something that can,t be moved that easily,but yes they can also go up.So when you say 4 x 90 deg is that to cover 180 deg area,2 for each side set at different distances for example 10 meters and 5 meters.Down low I would be concerned about prying fingers. What type of stand will the sculpture sit on. It might be possible to use , maybe 4 PIRS embedded it base with 90 deg. spread. Usually I see PIRS's mounted around 7 ft. high.
