Life fitness 2002 A080-92249-D000
AlbertHall
Joined Jun 4, 2014
12,663
Assuming you have power input and the two fuses are OK and that there is no power reaching the big bridge rectifier (on the other side of the board) look carefully at the tracks and the solder joints between the input and the bridge. Also there should a common mode choke which you should check. That might be the large black rectangle about half way up the board from the fuses.
LYNDONBOC
Joined Dec 7, 2017
5
LYNDONBOC
Joined Dec 7, 2017
5
Fuse going to relay they have supply but going to rectifier is 0 volts i change already the relay but its the same....thank you so much for your reply sir.God Bless you more
MaxHeadRoom
Joined Jul 18, 2013
30,881
The route from the fuses to the bridge rectifier should be short and obvious to trace.
Do a little reverse-engineering and it should may be clear it up?
Max.
AlbertHall
Joined Jun 4, 2014
12,663
Yeah, you will need to follow the tracks and see how the power is supposed to get to the rectifier, then you can check where the problem is.
