Did you cross the polarities (positive to negative) ?I connected a 3.7 Li-ion battery to a 100uF capacitor with 30 volts initial voltage. The capacitor is discharged and the battery voltage became -1.4 volts (negative!).
Is the battery damaged?
The polarities were correct.Did you cross the polarities (positive to negative) ?
Are you saying you connected a charged capacitor to a dead battery?It's 600mAH and It did not have any charge when I connected it.
The battery was healthy; but it's not charged now.Are you saying you connected a charged capacitor to a dead battery?
That's my bet, although I can't explain a negative voltage reading. The battery itself is not likely effected, only the circuitry. The capacitor's charge would be a drop in the ocean compared to the battery's capacity.However if it has protection circuitry built into the battery, maybe the tiny voltage spike tripped something?
thanks, I learned alot.Hi,
I FIRST have to ask why the heck anyone would do such a thing?
Li-ion cells have to be charged carefully and with a special charging routine.
A 100uf capacitor at 30 volts can put out 300 amps for a short time, about 10us.
At 30 amps about 100us.
The current depends on the ESR of the cap and the lead resistance mostly.
But most important is that if 30 volts appears across the battery for even a short time, it can jump the small gaps inside the material and short out the cell, and if there is enough energy stored or left from that it can cause the cell to explode and/or catch fire.
Li-ion cells are not the things to be played around with or some serious damage may occur.
Be careful what you try.
If there was a protection circuit in there it probably had activated to try to stop such an explosion and so may have permanently incapacitated the cell. Best bet is to get a new cells and discard the damaged one as it is very hard to determine if any damage is a safety hazard in an Li-ion cell.
After some charging, now it has zero voltage.Have you even tried charging the battery? How do you know there's any problem with it? If the battery was discharged, the protection circuit may have disconnected it from the terminals until it gets a reasonable charge current. The -1.4V may be an artifact of this disconnection. Or as Les says it may be fried. But trying to charge it should shed some light on it.
Unless it's a bare cell with no protection circuit. In which case if it's at or below zero volts, it's dead.
It's like the battery in the attached figure. Dimensions 3x4x.5 cm with two wires.@abjadi
Is it a battery pack or a discrete battery??
OK, as it is right now the pack is dead. I suggest that you open/unwrap it. I suspect that something other than the battery failed. If you open it you may have the opportunity to fix it.
