Hello Guys,
I wanted add a disconnect circuit using MOSFET switch with microcontroller as per below. uC will cut off charging using mosfet in series so user have control to charge the battery.
I wanted to use mosfet based switch and i tried to do LT Spice Simulation but i am confused if it is correct .
I assume battery will always have charge of 3V to 4.2V when user want to charge it. I am not sure if this circuit works well as per my thought.
battery cut off is 3V
Could anybody help me ?
LT Spice Circuit is attached here.
Thanks in Advance !!
