New to forum, stumbled on it while searching for info about an LG washer. Thanks to all for sharing your knowledge and interest!
Let me know if a new thread is preferred, don't want to divert...
Goal:
- Modify an LG washer for use as a greens spinner on a small farm
Context:
- We are using the spin cycle with unmodified controls. We want to operate with the lid removed, which means we want to defeat the lid safety interlock.
- There is a door lock mechanism that includes a motor and sensors. The wiring diagram shows 2 motor connections and 3 switch connections (attached)
Questions:
- What is the "Lid SW" on pin 5? Is there a magnetic interlock or is this a mechanical switch within the mechanism? Is this used as an indication of the lid being closed BEFORE the lock mechanism is actuated?
- I can bypass the mechanism by closing the switch connections on the PCB and simulating the motor loads with resistors. But... is there any way to predict if this will work without having to match a "sequence". Basically, does the FW require sensing a sequence of events or can the FW be satisfied by closing all the switches or, for example, closing the "door closed" switch and leaving the "door open" switch open ??
Thanks in advance for your thoughts and insight.
Mod: link to old thread.
https://forum.allaboutcircuits.com/...ne-control-board-question.114147/post-1552595
Goal:
Context:
Questions:
