Hi, I'm trying to troubleshoot an LG 60lb5200 LCD that gets no power. I've tested the power supply outgoing pins, and get no voltage from any of them. The bottom pin reads 'EN' which I have to assume is the standby voltage.
I have also tested the output of the main transformer and get no DC voltages. Does the standby voltage come out there? The fuse is good and is reading normal AC voltage across it. Can someone lead me in the right direction so I don't have to pay $100 to replace the whole board? I've included pics. Thank you!
