When I was about 12, I took the bulb of a small flashlight and soldered a wire to each of its two poles. Then I plugged the wires directly into a 120VAC outlet to see what happened... Lo and behold! the bulb flashed intensely for a very brief moment and then it turned completely silver! ... it wasn't until years later that I understood that I had vaporized the filament and its inner surface became coated with it... and I was also surprised that the bulb didn't explode... I should've kept that thing as a souvenir, but I lost it.
