Hi all.
Please bear with this long post.
I know how to change a fuse. I know how to wire a plug. I know how to change a light bulb. I know..........
Actually. that's about it.
When registering here I had to tick my interests. I didn't understand what any of them meant so just picked two.
As you can probably tell...... I'm out of my depth.
I work for an architectural marketing company and an area we're going into is 3D printed models for our clients. This will be one of my areas.
The 3D printing isn't the issue.
However, I currently have two problems.
I'm hoping someone here can help me with one or both.
LIGHTING UP PRINTER
I want to do timelapse recordings with my printer but it isn't a lit system. I either need to keep my bedroom lights on for X amount of days while printing or light the printer another way.
I've thought about just getting a couple of LED desk lamps (the lights shouldn't give off any heat as this can mess up the print) but I'm getting more interested in learning how to wire up and control lighting myself...... Ideally without killing myself in the process.
Where my type of printer is concerned, I can see loads of people doing loads of different things to light up their printers.
Me, I don't feel confident wiring stuff to the printers PSU (as some do).
I see a lot of people using this:
https://www.ebay.co.uk/itm/2pcs-coo...282110309131?_trksid=p2385738.m4383.l4275.c10
It seems to give off decent light. I can print something to attach it to the printer. It's the electrics that I'm nervous about.
Ideally, what I'd like is to be able to connect this LED to an on/off switch and either to a USB or a UK mains adapter.
LIGHTING UP MODEL
Next on my list of aspirations...... to light up my printed models.
Giving a client a printed version of their property is all well and good but if the model could be lit from the inside, it'd add that extra touch.
Here's my test/example/showcase model. I'm going to be using 1mm perspex for the glass.
Because I don't know what the hell I'm doing when it comes to lighting, I'm delaying the printing of this because I don't want to spend ages printing it and then have to reprint when it comes to lighting it.
It can either be lit from the roof or the floor. However, the roof will be removable so I won't want wires seen all over the place.
The more I'm typing this, the more I realise how out of my depth I am so might just leave this here and hope that someone can give me some kind of advice other than to give up.
Thanks.
Sean
LIGHTING UP PRINTER
LIGHTING UP MODEL
Thanks.
Sean
