led's in parallel does the resistor get attached on the + end
ericgibbs
Joined Jan 29, 2010
21,561
hi 6666,
Welcome to AAC.
Your circuit is correct, but it is not good practice to connected LED's in parallel sharing a common current limiting resistor.
Most LED's do not have exactly the same same forward voltage drop.
E
Ideally one resistor in series with each LED. The combinations can be paralleled.
The color of the LED affects the value of Vf used to calculate the series resistor.
ebeowulf17
Joined Aug 12, 2014
3,307
The handling of resistors for the LEDs is correct, and would also be ok with each resistor on the cathode instead of the anode - as long as each LED is in series with one resistor it won't matter which order they're in.
I'm curious about a different question: Is the switch where you want it?
In your first schematic, the LEDs would be on all the time, and the switch would only control the motor.
In your second schematic, two of the LEDs would be on all the time, and the motor and third LED would be controlled by the switch.
