Led switch - Diverting power from one led to the other (Red/Green 1 action)
Wanezaq
Joined Jul 23, 2020
From a IR/switch led light, i am trying to use 2 lights with one switch.
It currently turns light A on or off,
but i want it to switch between light A(original) and light B(added)
RED/GREEN one light always on, switch on press
Reloadron
Joined Jan 15, 2015
7,980
You are going to have to explain that better.
Switch between A & B implies only one LED is illuminated at any one time. Then you follow up with:
Now what do you want? Switch on press as in a push button switch? I have no idea what you want? If you want to alternate between A & B then you need a SPDT switch.
Ron
28,621
What the TS did not mention is the actual voltage and power being switched, or the available voltage, if it is conveniently available. So all answers are guesses. For minimum parts it can be done with one SPDT switch and one resistor, plus the 2 LEDs.
