LED Strobe
Icanmakeit67
Joined Sep 23, 2018
216
Looking around in past post but not really seeing what I want…
looking for the simplest 2 LED strobe that alternates back and forth flashing twice each. Runs at 9vdc. Example Left LED, quick flashes twice then the Right, LED quick flashes twice and repeat until powered off.
I don’t have time duration but I think most of us have seen something similar in the grill of a police car or on a construction vehicle, even on some mail delivery vehicles. Again nothing fancy. ICs are ok but not wanting to program anything…
Thank You
Jerry-Hat-Trick
Joined Aug 31, 2022
852
Maybe use the trusty old 555 as an astable to trigger a 4017 decade counter with Q0 connected to an LED via a resistor to ground, Q1 left unused, Q2 to the same LED, Q3 unused, Q4 to the other LED and so on. Q8 connected to the reset pin. This should turn the LEDs on with a 50/50 mark space ratio
There are examples of the 555 with the 4017 to make an “LED Chaser” on the web which can be adapted as above
Icanmakeit67
Joined Sep 23, 2018
216
Thank You. I have seen these. I’ll check it out
eetech00
Joined Jun 8, 2013
4,731
Thank You
Does this need to be a "triggered" circuit or begins flashing at power on?
dl324
Joined Mar 30, 2015
18,476
your sources of circuits must be vast. Very kind of you to share this circuit.
I drew it from scratch.
The values of resistors/capacitors critical? I can experiment…..
Depends on the alternate and flash rates you want. You can use this nomogram from National Semiconductor to estimate values. Or you can do the calculations from the datasheet.
If you make RB much much larger than RA, you'll get about a 50% duty cycle.
If you din’t want to go with the micro, the 555 and 4017 solution is much better.
Thinking about connecting two outputs of the 4017 to one LED makes me wonder if it’s okay to effectively connect two outputs together. Maybe, instead of connecting the LED directly (with one current limiting resistor to ground) the outputs should be connected to the LED via a resistor at each output, or maybe a diode for each output and one resistor from the LED to ground.
Perhaps someone could say if this is necessary, I’d probably use diodes to protect the 4017 just in case!
28,417
It will take two CMOS ICs and some high gain transistors. two hex inverters for a one device pulse generator, (CD4049) then a CD4017, with outputs "0" and "2" triggering one transistor to light one LED for two flashes, then outputs "5" and "6" triggering the other transistor to flash the other LED. Two buffers diode-OR'ed for the two quick flashes. And run it all on 9 volts with a resistor that allows more that the 20 mA because the flashes are short.
The LEDs can handle a fair amount more for shorter time periods. The transistors can be MPSA12 or 13 so that they can switch on fully with a CMOS direct drive. And it could be only one current limiting resistor because only one LED at a time will be lit. Or a resistor for each color if different colors are used.
