LED strip with potentiometer howto
zogorean
Joined Jan 12, 2013
11
Hello all.
I just purchased a 3m long LED strip and mounted it behind the bed hoping it would be a nice and cousy lightsource. However it shines too bright, and therefore I want to be able to adjust the brightness. The transformer outputs 12v 2amp max.
Can someone tell me what to do? Many thanks in advance.
35,268
You need a light dimmer circuit that uses pulse width modulation (PWM).
A 555 timer circuit driving a transistor would be one solution.
Alec_t
Joined Sep 17, 2013
15,159
I don't see how the circuit in post #3 provides PWM? The output from the 555 is constant-width pulses and Q2, although pulsed, is never switched fully on.
#12
Maybe that circuit is worthless. It's just something I picked up on AAC.
Then again, if O.P. never responds, it doesn't matter. :rolleyes:
If he does, I'll try to fix it.
