LED strip question
ToasterTanLines
Joined Dec 26, 2021
11
Hi there,
I'm doing a little LED project at home, and have so far completed what I had set out to do. However, I still have a segment of LED's left over, and I wondered if this new idea would cause any problems.(?)
I have cut my led strip to fit two different areas. I have the first segment of the LEDs running free (always on), and then they connect to a reed switch and another segment of LEDs is connected to the other end of this reed switch (basically I have some LEDs on all of the time, but when I open a cupboard, some LEDs inside will turn on). I still have a segment of LEDs left over, and I have an idea of how I could use them, but I want this segment to also be on all of the time. If I run the 12v from the segment before the reed switch (from the end of the first segment), and to the third segment, will this cause any issues? (The RGB wires will run from the end of the second segment and the 12v from the first).
Hope that makes sense!
BobTPH
Joined Jun 5, 2013
11,616
It sounds like the R, G, B wires go directly through the two segments and the 12V wire is interrupted by a reed switch. If that is correct, the wiring you suggest will work.
28,015
I have what I believe to be similar LED strip material The four conductors pass through from one end to the other, So until the current drawexceeds what the conductors are designed to carry, additional sections can be added with no problems at all.
