hello guys i want to connect 4 LED's and i do not know what power supply i should be using. the Led's are 350 mA 2.1 V. What power supply would i need?
NO!So a 8.4v 1000mA …18650 battery charger would work perfectly withot the need of residtors right?
Because then it might burn out the LEDs or not work at all.Why not 9 volts, and use a smaller resistor, and waste less power?
Do you have a part number or a data sheet for the LEDs you are using?hello guys i want to connect 4 LED's and i do not know what power supply i should be using. the Led's are 350 mA 2.1 V. What power supply would i need?
Those B version models are usually high voltage, designed for a high number of series LEDs. Small regulated 12 volt supply followed by a PWM dimmer may be in order. You will still need to figure the correct value for the series resistor .I think i could use a B version meanwell power supply so i can add a 100k ohm dimmer to dim them.
| C | Choosing the Right Power Supply for a Long LED Strip | General Electronics Chat | 11 | |
| C | Choosing a power supply for a long LED strip | Power Electronics | 10 | |
| K | Power Supply for Guitar pedals | Power Electronics | 17 | |
| D | DC motor controller/power supply | Power Electronics | 17 | |
Alternative power supply | Power Electronics | 2 |
