Hopefully you guys can help me out on this one, I might have gotten in a little over my head. I don't know much about electrical engineering, but am usually pretty decent at researching enough to piece things together.
I have an outdoor lighting project. I have to make some custom LED lights that will be fixed to stone walls. Off the shelf units weren't cutting it, and is why a DIY solution is in order.
For simplicity's sake, I'm going to just focus this thread on ONE of the walls, so 12 lights total.
Right now, I am looking at either using a 5w or 10w LED chip. Either this:
http://www.ledsupply.com/leds/cree-xlamp-xpg2-high-power-led
Or this:
http://www.ledsupply.com/leds/cree-xlamp-xm-l2-leds
I think 10w will be overkill, but I need to purchase some and test which will give me the amount of luminosity I need.
I need these lights to be app controlled to turn them on and off and dim them. I need to do this all the cheapest and easiest way possible. I can solder components, and I am building custom housings for all of these so that part isn't the issue. I am just a little lost on which drivers/controllers will be sufficient.
Talking to a friend, if I was to use the 10w LEDs above, we discussed using a 24V power supply and two of these http://www.ebay.com/itm/300-3000mA-...a473db983:g:wRUAAOSwo8hTopLs&autorefresh=true 1 per 6 leds. However, I don't think this is the best or easiest way to go about this.
Hopefully you guys have some insight. Like I said, I'm a little lost on this whole subject. Thanks in advance!
Or this:
