LED light organ
reno12469
Joined Jan 17, 2009
47
Is it possible to have a 12v LED rope light hook up to an LED light organ in a car using the 12v car battery? I found something that is similar but works with 4 LEDs and i was wondering if you could hook up the rope light to it.
bertus
Joined Apr 5, 2008
23,003
You could replace the transistors 2 4 and 6 by 2n2222 types.
The 2n2222 can handle the current you require.
Greetings,
bertus
Joined Apr 5, 2008
23,003
Then you will need a more powerfull transistor.
Something like a darlington transistor like a TIP120, that can handle upto 4 A.
Look afther cooling the transistor.
Greetings,
Audioguru
Joined Dec 20, 2007
11,248
The color organ circuit drives only a single LED on each of its driver circuirts. It will not drive a rope light that is a series string of LEDs.
It can be modified so that each driver can drive its own rope light.
