Does that mean you have decided on PIC because there are small arduino boards like the nano/mini if space is a problem. Are you making one of these units or multiple, if it's only one I'd just go for strip-board if you are wanting to make a number then a pcb might be more of an option. Of course you might really be just in this to learn about electronics and pcb design and that would be a different thing entirely.right where can i learn about the pic quickly? i want to make a PCB for my unit and not have to have a mounting option for the arduino, also going back to the ammount of fets, i would need one per unit right? I have been using the FQP30LN as my main project one but does anyone recomend anything better, and what kind of programing will i need to flash them as i want?
You only need a pull-down if you must keep the transistor off during boot-up prior to you program getting control of the output pin. You don't want to use relays as you are pulsing the leds it's much better to go solid-state.okay i understand i worked with arduino for a while and I had a lot of fun with it got some good patterns but always hated trying to perfect the fets. how should thy be wired up? could i just wire the gate from the microcontroller the drain to the leds and the source from my power? or do i NEED a pull down resistor on the gate ? and or is there any pre made FETswitchboards or relay arrays? im trying to make this simple.
Arduino's can take 12V normally.also im runnning this all off 12 V keep that in mind i will need a volatge dropping circut ... recomendations?
That sounds like a white LED but I thought you were using a preassembled coloured module. Just post a link to the actual part you want to use even if it's a module.Fv 3.5v
A 700ma
