Led Flame Bulb
Jerry-Hat-Trick
Joined Aug 31, 2022
849
There have been a number of recent threads about using the 8 pin ATtiny85 microprocessor on this forum which you might like to look at. You could have one output pin driving an LED turned on and off with quasi random numbers of milliseconds between on and off. The off periods should be shorter than the on periods. I can’t think of a way to make a 555 astable to blink an LED except with on and off periods of fixed values which would be unrealistic
Ya’akov
Joined Jan 27, 2019
10,300
Welcome to AAC.
Big Clive (YouTube) is the premier source for information on LED lamps, including specialist items. He has covered several flame effect LED lamps over the years with teardowns, analysis, and schematics.
The video below is an example, but you should check his channel for more. It is definitely the best place to start.
Alec_t
Joined Sep 17, 2013
15,156
I suspect the cost of parts to build one would be more than the price of a commercially available one.
Is this intended to be a mains voltage bulb?
