LED drivers Constant Current Output and A series Resistor
Adam Powers
Joined Feb 1, 2018
I trying to figure out when using Meanwell LDD driver, if I want to tailor the current to each series LED on the output to a specific current, should I use a series resistor in the chain?
Example: I have a 500mA output driver but I want to drive the LEDs at 400mA so I add a resistor in series to the LEDs...
Or, do I just Dim them with the driver's dimmer function?
Adam Powers
Joined Feb 1, 2018
Yes.
If that works, why would you want to fuss with adding a resistor?
Well if the driver is meant to work at 100% (no dimming) most of the time then it is more efficient. And the scale of the dimming would be able to work at 0-100% so it would have more resolution. (in my application dimming would be used 5-10% of the time)
I suppose that the resistor adds inefficiency as well though.
Adam Powers
Joined Feb 1, 2018
Yes, I see. Kind of. That is what i am trying to wrap my head around. So adding the resistor will simply make the driver up the voltage and not really limit the power to the LEDs then.
So in the case of the Meanwell drivers, The way that they achieve dimming is not by reducing current but instead applying a duty cycle to the max current. Is that correct? I believe that is what the data sheet is saying...
Adam Powers
Joined Feb 1, 2018
Thank you both. I understand. I can go design my circuit now. I will just get driver as close as I can to my target current without going under and then just limit the output through PWM.
LesJones
Joined Jan 8, 2017
4,509
In post #1 you say "if I want to tailor the current to each series LED on the output to a specific current" Do you mean that you want different currents through individual LEDs in the same series chain or are you running a number of series chains in parallel and want differen currents in each chain ? A schematic of how you plan to connect the LEDs to the constant current power supply would help us understand EXACTLY what you are trying to achieve. I have just tried to find a datasheet on you Meanwell LED driver but the company makes many different models. Can you provide a link to the datasheet on the MODEL THAT YOU HAVE ?
Les.
mcgyvr
Joined Oct 15, 2009
5,394
Sounds like a good plan..
They do have a 350mA version of the LDD too.. Then you don't need to worry about PWM to adjust average current..
Alec_t
Joined Sep 17, 2013
15,125
Some constant current drivers are sold as being adjustable. Is yours? Others might be adjustable with a bit of reverse engineering.
