LED driver dimming ratio
Gibson486
Joined Jul 20, 2012
360
Probably a dumb question, but when you have a an LED driver IC and they talk about the dimming ratio, what are they talking about? Is it stating what sort of dimming resolution you will get? Or is it stating that from the max value, you can dim to the ratio (so far a 1 A driver, with a 100:1 ratio, I can get no lower than 0.01A)?
thanks in advance!
mcgyvr
Joined Oct 15, 2009
5,394
Dimming ratio is the ratio of rated lumens to actual or minimum lumens..
So a 2000 lumen source dimmed to 1 lumen is a 2000:1 dimming ratio..
With your 100:1 ratio a 100 lumen source can be dimmed to 1 lumen... Or a 10,000 lumen source can be dimmed to 100 lumens or a 100,000 lumen source can be dimmed to 1,000 lumens..
All are a 100:1 ratio..
