Hi Gang
I built this LED Color Organ - http://blog.makezine.com/2010/10/18/circuit-skills-led-color-organ-spon/ - and it works great.
Wanting more, I modified it to drive three high-power LEDs - 400ma each
Problem is that I don't have the circuit around the TIP120 Darlingtons right exactly. the Red channel works really well, but the Blue & Green channels are difficult to balance, and after a while operating, the Blue channel just stays on - even if I disconnect the input to the base.
Also, when I turn on the power, all three LEDs glow a bit. Drawing about 11ma total, even with the base input disconnected, so it seems that the TIP120s aren't totally turned off.
Here's the circuit with my modification boxed in on the right side.
Can someone here tell me what I'm missing? I'm not a total electronic noob, but know enough to be dangerous. (as may be obvious)
Thanks!
- a -
Thanks!
- a -
