LED cascade: sans 555/4017
ThePsuedoMonkey
Joined Jun 27, 2012
2
Hello everyone! I have been trying to create an LED cascade circuit without using the 555 or 4017 integrated circuits. The best design that seemed to work in the Falstad simulator can be seen here (uses java). Essentially it's a few NPN transistors with a base-emitter daisy chain,each with 10kOhm resistors above the reference voltage, and the LEDs in series with the collectors. When I tried that circuit in my test board, nothing seemed to get it to work. I've seen a lot of info about the aforementioned ICs, but very little that doesn't use them. Am I being silly for attempting this, or am I making it too complicated?
KJ6EAD
Joined Apr 30, 2011
1,581
That RC bucket brigade approach can be difficult to balance. It's a good teaching example to show the advantages of digital logic over analog circuitry.
You can replace the 555 clock with one made from a 3 inverter oscillator or if you want to stick with the discrete approach, a 2 transistor/2 capacitor astable. Separating the clock function from the driver functions has some advantage in consistent timing but then you need lots of latches to replicate the counter function of the 4017.
You could use a smaller counter (4 bit) if you only need 3 outputs or you could use a shift register but then you'd have to include a method to load a starting value.
I get the impression that you want to do this using only discretes but have performance similar to the digital logic method, no matter the part count. Is this a school or science fair type project idea or what?
Take a look at using an astable oscillator followed by a 4-bit ripple counter, all made from discrete components.
ThePsuedoMonkey
Joined Jun 27, 2012
2
Nah, this isn't for anything as fancy as all that: just me trying to do a little mood lighting. You'd be right about me trying to only use discrete components; I tend to shy away from components that I don't fully understand. Plus they seem like cheating. :p The astable oscillator definitely seems like a good start. I tried building a ripple counter out of bi-stable multivibrators, but can't think of a way to get them to nest properly.
I did have a little victory with the daisy-chain method though: using the negative of the LEDs as the base terminal lets you string a whopping four of them together if you start the chain with a darlington pair. Not very impressive though.
18,182
...I tend to shy away from components that I don't fully understand....
Everyone does. But learn to embrace datasheets. With enough motivation, a datasheet, and a few words of wisdom from experts around here, you can come to "fully understand" things that were once an utter mystery. To me that's one of the most satisfying aspects of any hobby, learning a new tool.
J Power Electronics 4
