Led Blinking circuit
Status
Not open for further replies.
38,838
From post #11.
Not able to breadboard to confirm but values are in the ballpark.
That circuit will give a very long duty-cycle (the output will be low for just the short time it takes the DIS pin to discharge the capacitor).
You need another resistor in the timing loop to get a lower duty-cycle, as needed to blink an LED.
dl324
Joined Mar 30, 2015
18,474
3 leds and 3.3v supply from coin cells
You have to use a LMC555 because the bipolar version is only guaranteed to operate down to about 4.5V. With 3 LEDs, you need to operate them in parallel, each with their own resistor.
If the LEDs are blue or white, you might not be able to get as much brightness as you want.
sghioto
Joined Dec 31, 2017
8,756
Why do you say that, the timing is the same through R2. I verified that the circuit works just fine.
AnalogKid
Joined Aug 1, 2013
12,280
Note that the CMOS 555 cannot source very much current when running on low voltages. The datasheet suggests 2 mA when running on 5 V, and less than that at 3 V.
Consider the 74132 Schmitt trigger NAND gate. In the single-gate logic family (SN74LVC1G132), it has exceptional output current capabilities. Because it can source the LED current directly even when running on 3 V, a single gate can be the entire circuit. The parts and functions are the same as in #21, but with a smaller, cheaper IC.
Schematic later.
ak
https://www.ti.com/product/SN74LVC1...u0FrQxWig5yok8Gf6nGLSjB3Iot7Z3AVq7B6Ox81bZHrF
MaxHeadRoom
Joined Jul 18, 2013
30,815
There was one member here that wanted help extending the range of 3 banks of L:ED's , in order to fade in and out each bank in rotation over a certain time on a continuous basic.
I used a 8pin PicMicro with PWM control for each bank with an internal timer, worked like a charm, not that many components.
fahadrafi
Joined Jul 4, 2024
9
I have made this circuit in multisim. it works perfect but when I try it on breadboard, reset pin is not working, circuit continuously blinking even I cut off reset pin.
need help
35,196
need help
The 555-timer RESET pin (pin-4) is connected to the wrong side of the switch.
Status
