no. i want to make it by using a single icAs simple as possible? Use an MCU.
which MCu should I use?An MCU is a single IC. The only additional parts required are two resistors, switch, and LED.
You're going to need a bit more than that.it should be single ic led's and cells
You're the winner.Single 555 , 3 resistors and 2 capacitors.
At dinner right now but imagine a 555 astable using 1 cap and 1 resistor. Another cap and resistor from pin 4 to ground. A momentary switch from pin4 to Vcc and a resistor for the LED.You're the winner.
Let's see it.
The proposal is to put a 5-second RC circuit on the 555-timer reset.There are two things you want. Blink and 5 seconds.
There are some LEDs that blink all the time. Now you only need a 5 second timer.
I thought of that.At dinner right now but imagine a 555 astable using 1 cap and 1 resistor. Another cap and resistor from pin 4 to ground. A momentary switch from pin4 to Vcc and a resistor for the LED.
